Spring Cleaning
strikeeagle
(No matter that it was 29 F here last night). Here goes:
Terms and Conditions:
1. No pictures - seller is digital camera, computer, etc. challenged.
2. All prices are fair and firm.
3. Cash or money order only.
4. I will ship - continental US only - just as soon as funds are received.
5. To be fair, no PM offers please. I will not respond to PM offers.
6. First come, first served, based on the date and time of your post. Any indecision on your part, sorry.
7. I have tried to be as complete as possible in my descriptions. However, please feel free to ask any questions you may have.
8. All items are new or lighty used/as new. No disappointments - none - functionally or cosmetically.
9. Links provided for reference only.
Auto Meter Gauge Works Dual Gauge Pod 10400
Gray pod holds any two, nominal 2" gauges.
I've drilled 4 X 3/16" holes in the pod for the supplied rachet fasteners.
Includes pod, package of 6 new rachet fasteners, installation instructions, original box.
The fit, finish and color match of the Gauge Works pod are excellent and superior to any other pod I'm aware of for our cars.
Rachet fasteners provide solid retention of the pod to the factory A-pillar.
http://store.summitracing.com/partd...0400&N=4294925228+4294905606+115&autoview=sku
$20 shipped.
Kirban Performance Products A-Pillar Mounted Gauge Pod 6768
Gray pod will hold any single, 2-5/8" gauge.
Includes pod, double-sided tape, small plastic push button, original packaging.
Allows the use of, for example, a large, attractive, easily read boost gauge.
https://secure.mysuperpageshosting.com/kirbanperformance.com/index1.htm
$20 shipped.
Casper's V-Plus Volt Booster 102027
I have 2. These are plug-and-play - no wires to cut as with some volt boosters.
Includes installation instructions, original box.
https://www.casperselectronics.com/...creen=PROD&Product_Code=102027&Category_Code=
$50 each, shipped.
Casper's Audible Detonation Detector Module 102010
(Audible Knock Detector)
I have 3. 2 have crimp on disconnect type terminal ends installed to facilitate module installation.
https://www.casperselectronics.com/...creen=PROD&Product_Code=102010&Category_Code=
$30 each, shipped.
Red Armstrong Chipset For 009s
F 9 R93 6 0 (Street)
6 R100 6 0 (Street/Strip)
6 R108H 6 0 (Race)
These chips work - no thin or bent pins, nor have they been drowned or zapped.
Includes installation instructions.
Will not separate. This is a set, and will do you if you have 009s. Sell your other chips.
$100 set, shipped.
Pinion Snubber
I have 3 of them. 2 have black urethane bumpers under aluminum blocks, each with 2 countersunk allen head bolts. 1 has a
red urethane bumper under a black painted steel block, and it uses the factory fasteners.
If you want to use a longer than factory snubber, then here you have it.
The bumpers are as purchased, can be trimmed to length if desired.
$10 each, shipped.
GM Black Seat Belt Guides
These guides surround the belts, so the belts won't slip off as they do with the factory guides.
$10 pair, shipped.
MAF Support Bracket
I have 2. 1 is black anodized aluminum, includes bolt, flat washer, split lock washer.
1 is black painted steel, includes flat washer.
These are for use with your open filter MAF set-up. Do not leave your fragile OEM MAF unsupported.
$10 each, shipped.
Engine Tie-Down
This is the black rachet strap type. Handsome, all black strap - no fugly, third world, white stitching.
Fabric strap has "give", discourages alternator, alternator bracket failure. Includes eyebolt, 2 flat washers, 2 nuts.
$20, shipped.
Passenger Side Valve Cover Breather
Neck pushes into the grommet in the front of the valve cover. Includes bright metal cap (2), 2 sided tape and K&N air filter oil.
$20, shipped
"Positive" PCV In-Line Check Valve 518PCVCHECK
ATR/Performance Systems Manufacturer
Quality, cleanable PCV check valve for use in conjunction with OEM PCV valve. Includes hoses, installation instructions.
This is the Pete Tomka PCV check valve - the high quality valve that works, unlike most others.
$15, shipped.
Walbro GSS307 Fuel Pump 26797-1
GCA722-2
Includes 400-835 installation kit - instructions, adapter, hose, clamps, filter, o-ring, etc.
Includes plug-and-play connector - no wires to cut.
$50, shipped.
VDO Boost Gauge 150 121
30 In Hg to 25 PSI Boost (Vacuum/Pressure)
Turbocharger Gauge CV 150 077 004D
2-1/16" Diameter, Mechanical
Includes installation instructions (2), lamp socket (2), light bulb (2), green light bulb cover,
red light bulb cover, mounting brackets (3) and nuts (6), pressure fitting.
Black bezel, black face, white letters/numbers, red pointer.
This is the handsome, Vision series gauge, with through-dial lighting. Looks great, day and night.
http://www.sso-usa.com/performance/InstrumentSeries/Vision/index.html
$20, shipped.
Adjustable Wastegate Actuator
Garrett Airesearch
430819-39 05098 50911
With integral mounting bracket. Factory, not a cobbled, formerly non-adjustable actuator.
$50, shipped.
Thanks.
strike
if you will ship to hawaii i will give you 25
Engine Tie-Down
$20, shipped.
Pinion Snubber
Let me know where to send the dough and I will take a pinion snubber off your hands. Would like a black one mounted on aluminum block. :D
Thanks very much for the replies, gentlemen. I will put together a list of who's getting what this afternoon, so that we can keep the transactions moving forward. Be back shortly.
strike
Guys,
OK, here's what things look like to me.
If you requested an item(s) but aren't listed it's because it was spoken for before you got in. However, you're in line if something should fall through, unless you edit or delete your post, in which case I won't be able to keep track of you.
Sorry, im faster, no shipments to Hawaii. Wouldn't be fair for me to break my own rules. Consider it your punishment for living in paradise - :D
I will be EMing or PMing the "winners" today as you've indicated with my snail mail addy. Again cash or MO only.
Thanks.
If for any reason you are not completely satified, please let me know and we'll get you happy.
strike
PS - Somebody buy the rest of this stuff, will ya?
$20 shipped.
1 - INEEDAGN
$20 shipped.
I have 2.
$50 each, shipped.
1 - Rick87GN
I have 3.
$30 each, shipped.
1 - terryjh6
2 - Whtlightning
3 - WeAreVenom
$100 set of 3, shipped.
Pinion Snubber
I have 3.
$10 each, shipped.
1 - Dreamcar86 (aluminum)
$10 pair, shipped.
1 - TURBOTWIN2
MAF Support Bracket
I have 2.
$10 each, shipped.
1 - Dabigguy (aluminum)
Engine Tie-Down
$20, shipped.
1 - Killa-Cotton
$20, shipped
$15, shipped.
1 - Rick87GN
$50, shipped.
$20, shipped.
1 - Whtlightning
$50, shipped.
Guys,
Sent EMs to:
INEEDAGN
Rick87GN
terryjh6
TURBOTWIN2
WeAreVenom
Whtlightning
Sent PMs to:
Dabigguy
Dreamcar86
Killa-Cotton
Let me know if you DIDN'T get my EM or PM with my snail mail addy. Otherwise, I'm looking for your cash or MO. I will notify each of you when I get your funds, and will get your stuff out to you as soon as possible thereafter.
Thanks.
strike
