Sounds like a lifter is going out in my tranny...help.
Kid with a toy
Shaven Member
Here's the deal:
My tranny just started making this clicking sound...like a lifter would in a block. Is it the pump trying to go out?
It makes the same noise no matter what gear (P-R-N-D) and steps up with the increase of RPM's. The tranny is bone stock, and has a 2800 stall blue streak TC. And, yes, it has fresh fluid.
All advice taken...believe me I need it.
Erik
I haven't got the car up in the air yet...but you can bet that will be on the top of my list.
Thanks...
Erik
loose converter bolts, cracked flexplate, pump rotor cracked, bad vane ring, cracked neck on converter but most likely a cracked pump rotor.
Bruce
WE4
Hey Bruce,
Would I be correct in saying that the pump rotor is something that should be handled by a professional? In other words, keep my hands out of it. :confused:
Erik
If you want perfection......
then follow this... if you can. :D which is kinda difficult to say the least..... anything other that this is playing "rotor roulette"
Hopefully you'll get lucky and just have lose verter bolts. ;)
*PUMP BODY: First, never use a pump body twice unless you are reinstalling the SAME pump rotor,slide,and veins,
that came out of the running trans. If you are going to reuse,modify pump body as will be explained and reinstall. If pump rotor,slide and or body needs to be replaced start with a "refinished" body. The ONLY way to correctly do this is a tideous and time consuming method. First, our experiance has led us to use GM parts EXCLUSIVLY and they must be ordered in sets from them(GM) at the request of the builder. They must be exact to .002. This is how we do it and have been commended on it by GM themselves:
Use only GM parts ...slide,rotor,veins,all purchased at the same time, all measured at the same time. 10 Vein is more than enough. Reason for increase in vein count, was to try to knock down the pulses or pulsation of the pump. We noticed quite an improvement from 7 to 10 but not much more 10 to 13. We still use the 10. GM actually has 16 different part numbers for slides and rotors. The aftermarket has 1!!!! That should tell you something!!!!
Remove any burrs in slide and rotor. (Yes,even if brand new right out of box is being used,as I have not seen one yet right out of box with no nicks or burrs at all, Not one.) Wet sanding by hand in solvet and sanding edges with 600 or so over GLASS works well.
Wash in hot water and dishsoap and compressed air dry and set aside. The Chrome Moly ring kits have been known to be a little rough too. We wet sand with 600 over glass in solvent the flat edges and then fine wire wheel the circumferance. It is imperitive that the pump rotor and slide are measured very carefully. They MUST be within .002 of the pump cavity depth.
Too loose and line pressure will be low hot, and too tight, rotor and slide could bind, and break rotor, slide,converter neck,or all the forementioned parts. We set them .0013 in the hole, or in the "pocket". The way this is done is, the face is cut, or surfaced. Then another tool bit comes in and with the premeasured rotor and slide thickness', cuts it to .0013 clearence. This is VERY IMPORTANT!!!!!! . The CNC mill then cuts the relieve groove in front to allow more drainback behind seal relieving pressure on seal. (On the 690 pump bodies , Gm did this. On the 082, 149 pump bodies they need to be modified.)
All are done on a CNC machine. That is how they were done originally, and this is the way it should be done now. If you have a good pump body and have the ability to measure it to the thousandth, you could play rotor roulette and get your calipers out and measure 50 slides and rotors before you get two that would fit, PERFECTLY. AND, you could probobly pull it of, but it is not exact. And........another point or intrest would be...... the aftermarket ( parts co's) gives a tolerence of .7071-7076 which is six thousandths and the tolerence for the pump is two thousandths, THIS WILL NOT WORK!!!! It will be either too loose or too tight. See the problem with aftermarket 10 and 13 vein swaps? Now, all the 13 vein rotors and slides I have seen are all on the thicker side of the scale so most will bind when hot if not properly clearenced.
Ok, now we modify the pump return hole by drilling it to 9/64ths. From both directions.
In pump bushing bore the 690 pump bodies have a "step" at which the bushing seats against when installed. The 082, 149 bodies do not, so we mill a slot on three sides of bushing bore 1/4 inch down. After red loctiting the teflon coated bushing, press in hole with arbor press and bushing driver. Then , "peen" the bushing or "stake" the bushing into the milled flats. Flip over , and press in red loctited seal into seal bore. Assemble all pump rotor parts in , of all things, Cam shaft install lube. The red stuff.
