Your standard garden variety "hobbs" switch is a set of contacts that (in some cases) can be adjusted when the switch "switches". Some are "N.O." or normally open while some are "N.C." or normally closed. Seems simple enough even to my simple mind. The setpoints can be adjustable. This is simple enough and would allow you to control one LED. Without using a relay, I would think you would want the N.O. variety and when it closes... it lights up the LED.
What I want..... is........ 2 small LED lights hooked up so that when I come up to the line..... and start building boost..... the 1st LED lights up at say 4 psi boost..... then the second LED lights up at say 8 psi boost.
In studying the different part number hobbs switches available at "allied electronics", they list some "dual-circuit" adjustable hobbs switches. Basically they have 3 terminals..... have a NO and a NC set of contacts, and they can be adjusted independently of each other. I think this $30 switch might do what I want with only having to purchase one hobbs switch. In this case, I would have to wire a SPDT relay on the NC contact to make the LED light up when that set of contacts broke.
Where it gets "fuzzy" is which part number switch I need.
http://www.alliedelec.com/images/products/datasheets/bm/HOBBS_INC/70111546.pdf
Part no. 77048
Looks like I could set the NO contact to close at 4 psi...... and the NC contact to open at 8 psi...... and be able to tweak either setpoint one way or the other...... In my example.... I'd be targeting a launch boost between 4 psi to just under 8 psi.... which should be obtainable without blowing the tires....
In theory, since I don't have a fancy external gate......I would stage.... begin to build boost.... and when I lit up the 1st LED... I knew I would be at or more than 4 psi..... but not wanting to leave too hard and blow the tires.... I would still want to make sure I wasn't about to leave on too much boost.... which is what the second LED is for. If you blow the tires away at the launch... it is a wasted pass..... so I would want to know if I saw the second LED light up.... that I might be about to launch at more boost than I really wanted to. In my case, my car has HB brakes and it will build 14 psi (track verified and on my datalog) without even trying to push through the lights. Bottom line is.... she won't normally hook on a test-n-tune night on a 14 psi launch..... With a creative LED setup.... it might be easier to find that happy launch boost...... without going over....
IMHO, the LED setup would be easier to launch this than studying a boost gauge. Just something else to try.... Obviously a perfect launch would would be easier with a CO2 powered external gate.... but that is not an option right now.
Anyone played around with a dual circuit hobbs switch?
Part no. 77048
