U Underboost Mr. Dull Joined Oct 4, 2005 Mar 18, 2007 #1 Can you run a solid roller cam with the stock ecm?
O Otto J Well-Known Member Joined May 31, 2001 Mar 18, 2007 #2 Dont see why not,Just need a properly burnt chip to make it run correclty
N nordy racer Active Member Joined Aug 2, 2004 Mar 19, 2007 #4 going all out a see Brent. must be nice big dog..
U Underboost Mr. Dull Joined Oct 4, 2005 Mar 19, 2007 #5 nordy racer said: going all out a see Brent. must be nice big dog.. Click to expand... I'm just checking. I'll change my gears first.
N nordy racer Active Member Joined Aug 2, 2004 Mar 19, 2007 #6 Underboost said: I'm just checking. I'll change my gears first. Click to expand... Sure
750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Mar 19, 2007 #7 What size cam are you running now? You're running 3.73's with a 28 inch tall tire correct? Neal
L Lee Thompson New Member Joined May 24, 2001 Mar 20, 2007 #8 ? Still able to use the factory knock censor??
750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Mar 20, 2007 #9 It's still screwed onto the block but its not plugged in. Neal
G Googs I've "GOT BOOST"! Joined Mar 13, 2005 Mar 20, 2007 #10 I'm running one right now in my car, with the knock sensor still hooked up also. No problems at all.
