SMC progressive kit
Turboboy
I just installed a smc progressive kit and double checked everything. with key on all three lites are on, (armed,spray,low) The bottle is filled completly, When you hit the test button the motor stumbles and the low light goes off, but as soon as you let go the low light comes back on.... any ideas? Thanks :confused:
had the same issue make sure the ground comming from pump is properly grounded:biggrin:
