good idea I need it recovered anyway. Mine doesn't leak, at least not inside the car. It has tubes going down all four corners to run the water out past the body. I read that the seals are not intented to stop water but to guide it to the tubes. I tried it the other day, and it makes a solenoid sound, but does not go up or in. Also, one of the clips on the sunshade busted off, and it is jammed cockeyed and will not slide back. The headliner material is completely off of the sunshade, was drooping real bad so I yanked it thinking that was hanging it up. I'm still thinking of going with a new roof since the Skytop is not original, but it would be good to pull the headliner down and see if it could be fixed cheaply. My only fear is, I had it repaired twice already, so if it goes after this, more then likely it will be after the car is painted, and I will be screwed to put a new roof on then.
