Just finished installing the motor that was assembled by Don Cruz and Im having issues with oil seeping from the oil pump that is entirely my fault...when I was trying to install the new motor mount on the passenger side of the motor (hammering a little on the through bolt) I accidently got a few very minor surface scratches on the front cover surface (no burrs and nothing major) I was afraid to do anything to it before I knew it would be a problem because of tolerances with the pump gears etc.
Its not leaving pools of oil but maybe a good 2 inch spot over night and is getting oil of course on crossmember etc.
Should I pull it apart and try and get it to seal or just live with it?
I dont want to change this front cover in case some majic oil mods were done during assembly
