v6turbojunkie
- Mar 14, 2004
I've got a Wolffe rear suspension with adjustable uppers, lowers and anti-roll. I was using the foot brake to launch and had the pinion set at zero. I've switched to a trans break and can now build lots of boost and rpm's at the line. Problem is the tires go up in smoke immediately. I'm using GYear 28X10's @ 11 psi. Where should I go with the pinion angle and how much?
Thanks, John
Thanks, John
