85 ttypewh1
fire fighter
- Jul 25, 2004
just got my ez link update to monitor my sensors. Problems with the car are a harsh 1-2 shift but at the right mph, Rough idle then the ecm will correct it mostly just at start up. car has 198k miles but is clean and well taken care of. replaced all vac lines because of dry rott and loose fit. my readings at idle after about a 15 min drive with a/c off are 02 volts vary from 0-831mv, tps 1.82, maf 8-10, int 128-134, blm 128, lv8 or load 48, iac 79, knock sensor starts at 3 and i notice when the car just started it was running rough and stalled and the # was 250 approx.i have an idea about some of the things out of wack but just want to get a second opinion because i think if i fix the right one first it may correct some of the others. Thanks for any advice.
