T
TwinT66
Guest
When recording a run everything is okay and i can play it back with no problem.
The problem is when i try to play back the run in the VE,timing,and the A\F sections I get
a sensor error and then it says rpm\map.It will show 0 rpm while the other sensors on that dashboard show readings.
Also when installed the fp disk into the laptop then went to the install option disk for the
wb sensor it said sensor mismatch.
If anyone can help resolve this ,I`m suppose to be heading down to the high tech shootout
in NJ saturday.
Thanks again
Tony
in NJ saturday.
Thanks again
Tony
