I've been chasing high BLM's for a bit and used a home made leak tester (air compressor, soup can & rubber coupler) on the throttle body and found a good leak where the plenum meets the intake. I tried the following with no results.
1) tightened the bolts
2) took off the plenum and reassembled with new gaskets and used RTV gasket maker all around.
3) smeared RTV around the back of the plenum
It is an RJC 3" throttle body & plenum combo with a power plate
Is there a better sealant or gasket I can use to remedy this?
