Greetings folks,
After the car is driven for about ten miles, and thereafter whenever I take slow, tight turns, the rear makes a very distressing clunking/groaning noise. The clunks can be literally felt as well as heard in the cabin.
The problem has been getting steadily worse over the past year, and that, despite regular fluid/posi-additive changes.
What's wrong here?
Today we suspended the car on a lift. With the trans in park, and with a person grabbing each rear wheel, we weren't strong enough to be able to rotate one wheel with respect to the other.
Is this to be expected? Is the (stock, original) posi-unit on the fritz? And if so, what's the likely cause/remedy?
Any advice or ideas would be very much appreciated!
Best regards,
MAP
What's wrong here?
Best regards,
MAP
