firstReady to buy a scanmaster. What is the newest version? As always thanks all for your help!
I recommend the opposite. You can't see what's going on as it is going on unless you have the Scanmaster display to view.first
Get a powerlogger first and tune your car. Add a Scanmaster after you tune. Brad
I hope it was an AC Delco.Also new filter while I was under there.
Yes, Got it from my GM dealer.I hope it was an AC Delco.
Good to hear.Yes, Got it from my GM dealer.
Did I give you the impression that I didn't use one?I can clearly see that you used a scanmaster to tune your car. Look at your signature. Brad
No need to apologize to me. Your comment led me to believe that you were under the impression that I didn't use the Scanmaster and was recommending not to use one. I assumed that you misread what I wrote. Did you think I was putting down the Scanmaster?I apologize. I have been warned about my comments and will change my tune or banishment is in my future. Have a nice weekend and enjoy. I am going on a well needed vacation. Brad
No. I just feel that a Scanmaster is a far much better tool to be used after your car is tuned. It will tell you when you need more information. BradNo need to apologize to me. Your comment led me to believe that you were under the impression that I didn't use the Scanmaster and was recommending not to use one. I assumed that you misread what I wrote. Did you think I was putting down the Scanmaster?
If you record data with a Powerlogger and don't have a Scanmaster to view,you can't see what's going on until after the run when you view the recorded data. In other words,you can't see if you're hurting the motor when you're hurting the motor,so you keep your foot in it. The best thing is to have both,but if I could only have one,I would choose the Scanmaster for this reason.No. I just feel that a Scanmaster is a far much better tool to be used after your car is tuned. It will tell you when you need more information. Brad
Ttype6 said:If you record data with a Powerlogger and don't have a Scanmaster to view,you can't see what's going on until after the run when you view the recorded data. In other words,you can't see if you're hurting the motor when you're hurting the motor,so you keep your foot in it. The best thing is to have both,but if I could only have one,I would choose the Scanmaster for this reason.
That's normal. Can actually range anywhere from 000 - 800 when cruising. See attached.Just installed scanmaster 2.1. Is it normal during cruising speed for the 02 millivolts to be jumping anywhere from 80 to 760? Just learning. Thanks.
