DeltaBravo
Retired U.S. Army/Navy
- Jun 14, 2014
Yea...I used those as well. But realize, because you need to unbolt the relay to replace them, it is possible that after replacing both relays at the same time, they can be bolted back to the inner fender backwards from "normal".
As V6turbo87 recommended...I will be leaving both the TCC and low fan relay disconnected.
I should be picking up my new ECM in about an hour. I will give an update later.
In the meantime...is there a way to check the TCC solenoid without opening up the tranny? Other than the road test mentioned earlier in this thread.
