scan master
K Beauchamp
Just installed a scanmaster after having a few months and I lost the info sheet can anyone answer these codes for me. Thans Kevin.
1, af/05
2. L8/35
3. Int/128
4. 6L/143
5. ats/131
6. Iac/26
7. cc/137
8. pl/2.4
9. sp/26.5
data
I think:
1.af= air flow, yours is 5 grams per second = idle
2.L8= engine load 0-255 lowest to highest
3.INT= short term fuel trim, yours is 128, neutral reading
4.BLM= long term fuel trim,yours 143 lean, 90=rich 150=lean ECM adding fuel
5.ats= air temp sensor, yours 131F, death valley?
6.iac= idle air control, yours 26 OK, should be above 0 less than 50(just an opinion)
7.cc= cross counts, number of times O2 sensor crosses 0.450v switching from rich/lean, this number should climb to 255 then reset to 0 and restart
8.pl= :confused: I don't have this
9.sp= :confused: ditto
HTH
I was interested in getting one of these,i didn't know that they gave that much info.Which model number do you have and will it work if I have a mid 90's DFI in my car??
The only way it will work is if you have a piggy-back DFI kit and are still using your factory computer. If you are using a DFI computer, then it will not work. The part number you would need is SCAN2.
I think:
HTH
Hi guys!
Sorry to dig up such an old thread but i did a search on long term ecm and this one came up.
Anyway, i started up the TTA and the long term ecm reading is 160.
Can someone explaine for me why it´s so high and how i can get it down?
Regards from Sweden!
A BLM number topped out at 160 like that would indicate one or more of the following:
A vacuum leak, or a pre turbo exhaust leak.
