I have an 84 half ton chevy I use to plow with and in the winter it heats up to like 240 degrees while driving but not while sitting or plowing. You can watch the gauge climb as you drive down the road and fall at a stop sign. It has a 700r4 trans and the engine was a reman in the 90s and has about 60,000 miles on it. I have replaced radiator,water pump, fan clutch,cap, advanced and retarded timing and changed t stat 3 times and last time used a 160. Pressure tested the system and it held. No milky oil and dont seem to loose antifreeze. It does this with the plow off also. I even changed the gauge. This has been going on for 3 years now. Any ideas? Im am lost on this. Thanks for any help.
