Originally posted by Cheeseburger
The big difference is $$$$
With stage 2 heads you need to buy headers/efi intake/upper plenum and so on.
Stock type headers/intake do not work.
It's really not that much of a difference in price when you add up what you get and what you really want to have. Professionally porting a stock intake and installing larger throttle body isn’t all that much cheaper than converting a $100 4-bbl intake for EFI and getting an upper plenum. The stock stage II 4-bbl intake runners are HUGE and match nicely to the stage head. Remember, out-of-the-box un-ported stage II heads flow like 290. That's not too bad and can produce some really good power untouched. If you want to port them they easily go over 300.
Also, regarding headers. Stage II's use a 1 7/8" header, much bigger than the stock 1.5" ones. You cant' get 1 7/8" headers for stock heads without having them custom made, now you're talking more than the usually 1.5" stock style header everyone sells and more than the ATR stage II headers. I think Cal Hartline had a bunch of 1 7/8" headers made up for stock style heads, they sold almost immediately.
Also, with the stage heads, you can port them and fit valves as large as 2.09" intakes. Like someone else said, if you ever get to see a set of stage heads you'll know why the flow so well. Looking down the intake runners is like looking down a funnel, straight shot at the valve, same with the exhausts.
Regarding why TTA and Champion would make a stock style head that doesn't rival the stage heads, it's economics. Stage heads are not for everyone and won't work on a stock motor. The Champion head and TTA castings will work on a stock block. There are way more applications for a head that will work on a stock block AND stage motor than there are for only a stage block.
Yes, a stage head will go 7's and I'm sure eventually into the 6's (not taking into consideration that Buddy was already there). Remember, Champion heads are already into the 8's and I'm sure will eventually be in the 7's someday. I'm sure the TTA's are going to be at least equal to the Champion heads. Neither are slouches!
Hope this helps,
Art.
