Remove the door side rails. You will have to cut them out with an air cutting tool with a 4" wheel. If I'm not mistaken total weight reduction for the rails is 30+ lbs. You may also want to modify the exhaust system to include a small muffler with 3" pipe out the passenger side before the right rear wheel. The aftermarket carpets are much lighter than the factory ones. I personally like the plastic bumpers and aluminum aftermarket supports. The weight reduction is significant and unless you park your car at a mall you shouldn't have any problems. I have had plastic bumbers since 1988 when Kenne-Bell first introduced them without any problems. The other modification that you can make is to replace the drivers seat with a plactic race seat but cover the seat with a sheep skin type seat cover. You can pop in the factory seat after the race. Its held in place by 4 studs and nuts. I remember Jimmy Delesandro saying that when he would stage his car against another turbo Buick with equal power but with a couple of hundred pounds less weight no one knew or cared. The winner got the praise!
