UNDER-PRESSURE
..... Member .....
- Jul 16, 2006
I'm listing a very nice 10 sec. driveline package for a friend who is not computer savvy. Parts are located in Connecticut & he would like to sell everything together if possible.
FRESH 109 3.8L machined & assembled by R.P.E. machine in Connecticut
.30 over block, stock crank & rods, forged pistons, steel cap straps, ARP hardware, balanced
Solid roller camshaft, roller lifters, rocker arms, timing chain & custom pushrods
Champion ported heads & intake with KB throttle body & plenum, 72 lbs injectors, KB adjustable regulator, fuel rail, etc...
Custom sheet metal valve covers, ALL accesories, NEW Delco alternator & NEW mini starter
THDP 3" downpipe, stock manifolds, Caspers wiring harness, Stock ECM set up for low impedance injectors
BRAND NEW $1,500 Precision 6776 BB Turbo with .85 exhaust housing
ESP Front mount intercooler with pipes
HD Rebuilt 2004r with Precision 9.5 lock up converter, Stock GN driveshaft
6 Centerline Warrior wheels with tires. 2 skinnies, 2 with M/T ET streets & 2 with 28 x 10.5 M/T slicks
Engine is NEW & has not been installed or run since being picked up from R.P.E. I'm sure i'm forgetting some parts also & EVERYTHING Turbo Buick related he has goes with this package. SERIOUS buyers can contact JEFF at (203) 243-6618
................................................ $7,500 o.b.o .....................................
