While fixing my timing chain issue (link shown below) I decided to drop my oil pan and clean out the chunks of nylon in the pickup (yes, there were lots).
http://www.turbobuick.com/forums/en...ng-chain-does-look-like-normal-wear-tear.html
Since I have a slight rod knock and already had the pan off I figured I'd measure the clearance and install a new bearing to (hopefully) reduce or eliminate the knock. I know that this is a band-aid solution at best, but I'll be rebuilding the engine in a couple of months so I just need this motor to last until then.
Using plastigage, the clearance came back a little over .003". Since the target clearance for a street motor is 0.0018"-0.0022", would installing a .001" under bearing do the trick?
Also, would it help (or possibly hurt) to check all of the rod bearings while I'm under there and do the same thing for any that have excessive clearance in order to bring them a little closer to factory specs?
Thanks much,
Christopher
Thanks much,
Christopher
