Hatdragracer
- Jul 2, 2012
When bolting on the rocker shafts today. one of the shafts will not bolt on and allow smooth movement of all the rockers.
The issue happened when the rocker shaft was tried on both sides. I tried all combinations of mounting clamps with the same result.
Looking at it..when the clamps put in place all the rockers move smoothly, then when I put the bolts in the rear most rockers bind up and will not move. The very front rocker (#2 exh in these pics) has excessive side to side clearnace.
I measured the clearance between the spacer and the rocker on #2 exh with everything bolted down at 0.044"
My feeling is that the mouting holes in the rocker shaft are off a little and pressing the whole shaft rearwwards when bolted in....I just wanted to get a couple more opinions before I shipped the rockers back.
