Did you used the Quick Seat powder on your motor? Get any oil out the breathers?Originally posted by MSDGN
I went with Total Seal top gapless on mine...just did a leakdown and compression check after putting 550 miles on the new motor...compression was at 165 PSI for all cyls...leakdown was 2.3-2.7%
What seals did you have on your intake and exhaust valves?Originally posted by JeffG
I went with the Total Seal gapless top ring on my last motor....it's back in the shop gettting another going through becuase the thing smoked at idle like a two stroke.
I have come to find out that they make three different oil tension ring sets for that piston. My current motor builder tells me that total seals high tension ring is pretty comparible to everybody elses std street tenstion ring at 22lbs if I remember right. My last motor had their med tension rings which are 10-12ish I think. No good for a street car. Mine somked at idle, but cleared up under load. Then they have a low tension ring at about 5lbs.
I am going to try the Total seals again with my fingures crossed. The second ring will be a Napier type to aid oil scraping. I hope this combo does the trick. In the end, I think just a good set of file fit Hastings would have done the job. I always fall for the "latests and greatest" stuff
