C CutterTurboT BOOST Joined Jun 13, 2001 May 5, 2002 #1 I have some 26X10-15 in slicks and wanted to know on a 15x8 in rim what off set I need so that they want rub on the inside of the frame. Thanks...
C ChrisCairns Senior Member Joined May 24, 2001 May 5, 2002 #2 Originally posted by CutterTurboT I have some 26X10-15 in slicks and wanted to know on a 15x8 in rim what off set I need so that they want rub on the inside of the frame. Thanks... Click to expand... When I was running the 26x10 MT's had them on wheels with a 3½" backspace. So that would be ½" negative offset I think.
TR Custom Parts Mark Hueffman - Owner Joined May 25, 2001 May 6, 2002 #4 Anyone running 27x10.50x15 slicks (Hoosier Q/T PROS) on a rim with 3.5" rear spacing? Any clearance problems?
C CutterTurboT BOOST Joined Jun 13, 2001 May 7, 2002 #5 what is the bolt pattern (circle) of our Buicks for the stock rims and will a 15X10 rim with 3.5 in back spacing with a 26X10 slick rub the frame?
A azgn New Member Joined May 24, 2001 May 7, 2002 #6 5 X 4 3/4 bolt pattern it won't rub the frame, but it'll sure come close to the fender if you got weak springs.....
