T tttype Member Joined May 25, 2002 May 23, 2012 #1 Any tips on removing the input shaft check valve ? Tried expanding it like suggested in transgo non lock kit, but it just slid back into shaft.
G GNeric Senior member Joined Jul 26, 2003 May 23, 2012 #2 There is a land that will only let it go so far. I just use an EasyOut and knock it down into it until it grabs and then pull it out with a pair of ViceGrips on the end of the EasyOut while slightly twisting to the left. Takes about 15 seconds.
T tttype Member Joined May 25, 2002 May 24, 2012 #3 Thanks for info GNeric Transgo instructions are of little help. Ended up making a hook for a slide hammer & pulling it out.
