sorry this gets long.
Im not sure if pressures should be in the same range as a 2004r. But they look good according to some of the charts Ive seen. Other charts for the 200 have pretty high pressures.
But do these look good?
TV attatched at idle:
P 100-115
R 175
N 100-115
4 110
3 110
2 210
1 210
NO TV (detached from carb bracket)
P 70-75
R 115-120
N 70-75
4 70-75
3 70-75
2 210
1 210
Full TV
P 180-215
R 255-265
N 190-210
4 210
3 210
2 210
1 210
Any slight forward movement of the TV cable does result in instant pressure increase on the guage.
Ive already driven it up the road and back a few times through 1-2-3 but not 4th. Other then shifting way to late. it seemed to shift fine. It bumps right into gear and reverse, manual shifting shifts right away.
Also I did give it some gas a few times maybe half throttle, and it felt like it was really slipping bad, But Im pretty sure it was the converter, since I just changed to a 9 inch 3000 stall. Is this how it would behave? Does the converter make it shift later?
One more thing -- I set the TV cable by looking at the valve with the pan off. Set it so at WOT the valve was all the way in. (But I noticed when set like that, at idle I could only see 3 of the ribs, not 4 like Ive read). First started and pressure was high (130-140) So I backed it off till it reads around 100 at idle, but now at WOT I can still pull the cable slightly more? (this is a V8 with a holley and it does have the geometry corrector bracket)
Other then that, Im I okay to drive it?
Thanks so much!
P 100-115
R 175
N 100-115
4 110
3 110
2 210
1 210
P 70-75
R 115-120
N 70-75
4 70-75
3 70-75
2 210
1 210
Full TV
P 180-215
R 255-265
N 190-210
4 210
3 210
2 210
1 210
Thanks so much!
