Mr86t-type
- Feb 25, 2007
Finished the install, a few questions,
1. The Clear Turn-On LED is ALWAYS Green! I thought I read here that is was supposed to be RED??
2. When I shut the car off, the Clear/Green LED comes ON for a Second..Is that correct, you would 'think' it would be the opposite, and come on for a second at Key-ON??
3. It DOES Work as promised 21PSI on an AGGRESIVE 26-27 Degrees timing and ZERO knock!!
Oh, Two more things, the RED "ON" Light below the dial, mine NEVER comes on...is it Supposed to?? The Power Injection comes on, and Increases in Brightness as the Boost Ramps up....And, I read a few posts mentioning a "Pressure Module" yet I see NOTHING in the Kit about that????
