The new UMI lift bars might be the same or better than the original Southsides. Check with Mike Litch at Full Throttle. I remember the being reasonably priced.
Yes we now offer a lift bar similar to the SSM set-up. Our set-up does offer quite a few benefits over the SSM or Jegs set-up. One being we use a polyurethane bushing rather then a solid bushing, this helps to keep very nice ride quality and noise issues at a minimum unlike a solid bushing set-up. The poly bushings also won't bind as easily as a solid bushing. Another nice feature is since the ears are attached to the outside of the mount rather then the inside (SSM and Jegs) the control arm can be ran back in the stock location at anytime unlike other set-ups that weld inside the mount. With the SSM and Jegs this means you can only ever run there supplied lift bar unless the brackets were cut off, this is not the case with our lift bars. Also the lift bar we supply is the same length as a stock control arm.
