Has anyone installed a QuickSilver shifter on a 200r4, and had it under the stock console. If so, what kind of modifications had to be made. Any instruction, pictures, advice would be appreciated.
You will have to trim some of the plastic under the selector plate. Not much but you will . There may be some minor grinding that has to be done to the selector plate but thats on a case to case basis. After its done correctly none of the mods a visible on the outside.
Originally posted by kyturbo Has anyone installed a QuickSilver shifter on a 200r4, and had it under the stock console. If so, what kind of modifications had to be made. Any instruction, pictures, advice would be appreciated.
I installed the quicksliver in my car and another car and it looks good. You have to trim out alot of plastic from the console. The trim plate did not need to be modified at all.
You can use it with a 200-4r or later convert it to a THM400 forward or reverse valve body.
I removed the stock shifter mounting plates from the floor pan and installed 1/4" bolts thru the floorpan.
