been 7.30 at 203 on e85 at 3600lb and runs on the street . New ta engine kenny is building for me will be a E85 monster too
Keep us updated on that monster!
That sounds cool. Got any pics of the car?I don't know if it counts but I've been 8.3@167mph 1.24 60 ft (1/4 mile) and 5.1@137 mph 1.17 60 ft (1/8 mile). It's a SII tube chassis racecar, only thing is that it doesn't run quite on E85 but E100 ethanol with some oil added for lubrication.
just curious is it running a stock series II 3800 rotating assembly still ? I know zzp ran 8.6 on a stock block /rotating assembly in their FWD car and it would stand to reason on straight ethanol and in a tube chassis car one could go faster on stock rotating assm. /block
your also not far off from the series II 3800 record of 7.9......
wait am I missing something here? The 3800 buick engine's stock assembly can support power into the 8s? I feel like I am so lost right now (very common for me )
I thought he meant stage 2. If he means series 2...I definitely want to know more!
I meant stage II engine actually, sorry if I didn't express myself correctly
Got few photos here vkmmotors and some vids on my youtube channel.
Any spec on lube to fuel mix ratios?
how much lube added per fill up?
VERY interested
7.9 Gallons.There's a special cap that comes with the lube bottle. I use 1 1/2 cap to 30 litres of E100 - I'm in Europe, don't know how much is a gallon
So can a series 2 engine block out of a comaro work in our cars
rwd & fwd series 2 NA & SC share the same block but the fwd L67/l32 is set up to deal with boost better , thicker between the ring lands , lower compression , and coated pistons.So can a series 2 engine block out of a comaro work in our cars
