I got a 3 bar MAP sensor to log boost with my LM1 but am getting odd readings (using rpm convertor, not auxbox) . When setting up the channel that you want to log on, what parameters do you put into to tell the computer how to imterpret the data (ie x volts = y lbs boost). I grabbed some numbers off of their message board but when I did a log, the Boost numbers were entirely erratic. When my VDO boost gauge would read 12lbs boost, the LM1 was reading 4 for example. Also the graph of the boost channel was completely erratic. Any advice? Have you been able to log boost successfully?
