Pulling engine, Need help
LETHAL-6
Is there a way to pull the engine with the heads off? What Im asking is, is there anything to bolt to or to use to bolt to to do the pull? Any suggestions would be greatly appreciated. Thanks!!!
Could you bolt the chain to the lower intake? If its still on that is, i think thats what i did when i pulled mine the rear corner and front corner
I wrapped around the driver sead header. Not sure where else to go on passenger side for you, I used the hook.
Guys the heads are off so you cannot hook to the intake or headers.Is there not anyone else not that has done this?
if your not gonna use your old head bolts use them at the corners of the block on top with a chain between them..Works all the time and im doin it tomorrow.
Originally posted by 1987BuickGrandN
BlackMagic : that block looks damn small in that pic!
That's what my best friend with a Ford Lightning told me when he saw it :) Him and one of my good friends with a built 302 Mustang couldn't believe how small the block was :D
I guess you could say it's not always the size that counts :eek:
Its the motion of the ocean! heh
Yeah, I couldn't believe how small the block really is, I hvae a spare in my garage.
