Just picked up a set of 65lbs. injectors and looking to change turbos. What do you guys think would get the job done keeping in mind all the rest of the mods in my sig?
What size converter? Is it a 9" 10" 12" etc. The larger the converter, the greater the mass, the greater the mass, the harder it'll be to spool up a large turbo. a 10" 3000 should be able to spool both turbos with a good tune.......
With the 6131E turbo I have an 2700 stall and it spools great, probably a 3000 stall would be perfect. The times in my sig were produced with this turbo. The normal 61 turbo has a 52 exhaust wheel and will require a 3200 stall convertor minimum. This is with a .63 AR exhaust housing.
