Well it is finally up and running, got into it a couple of times and it is just causing the car to fall flat on its nose and show knock with O2's around 850mv. I have the turn on point at about 14 and the boost is only set at 16psi (normally knock there on 91octane). Also set to only run around 30-40%DC
What should I set things at for a good starting point? Last thing I want to do is blow another HG from knock. Hoping to get it tuned to 20psi on a stock turbo (no use going higher) and 91oct.
any help would be appreciated, thanks
