Powermaster
Dirty*6
This was in the trunk of my national when i bought it, don"t know if it works or not. Previous owner had already changed it to vacuum brakes. $245 with a free ride in the u.s. outside that we can work a deal if needed.
Just so you know as a core most vendors only give $125 for these. Also that one has the incorrect fluid reservoir.
Yup, wrong reservoir and nasty looking.
Sent from my P008 using Tapatalk
IMO - If it's found in a trunk, condition unkown then it's a core.
(Suppose you could install & test drive on a car to see if it's still good)
FYI - Kirbans currently giving $125 credit for complete cores.
Don't know if correct resevoir is required.
Believe there was mutiple resevoir variants on the powermaster though.
Yes different variants existed but for different model GM cars. The Turbobuicks all used the same reservoir design, which is not the one pictured.
