Above postings are good advice....
One thing that has been overlooked is determine what version brake bowl (accumulator) is on the side of your powermaster brake unit.
Original version is all black with nut inward to attached it. They are prone to fail big time.
The second version bowl from GM the nut was on the outer edge of the surface and you can clearly read the yellow silk screening words on it. That version is better.
The third version was made by Cardone (we help push them to make it & also sell it)
This bowl is larger than stock and nut is inward. It has proven to be the most trouble free bowl of all.
The cleaner the fluid the better it is in your system.....most expensive foreign car manuals recommend changing brake fluid every 2 years or so....GM did not although they should have with these powermaster systems.
Dirty fluid and brake bowls is most of the issues. While others may disagree based on cars we have sold and we have sold a bunch...the more original it is the more demand or more buyers are interested. In other words I would keep the powermaster set up on your car. We sell the rebuilt ones with a lifetime warranty.
Also as much as a pain is if you got a car with a power antenna...wait til that fails....major job to replace and new ones are not available.....
denniskirban@yahoo.com
enjoy your new ride.......may any oil leaks be minor ones!
