First-time-turbo-owner
- Nov 24, 2013
When I turn the ignition the powermaster will not shut off ( 45 seconds is the longest i let it go). If I pump the brakes once it will shut off after 2-3 seconds but then it blows the fuse 2 seconds later? The fluid levels are normal after the pump down 10 times. It does have the original accumulator but a new grey sensor.
