Here we go...my car has always whined when I turn. I have changed the power steering pump a couple of times, still whined. I became used to it. Last year I did the hydroboost conversion. Everything worked great, car braked better than ever, but the whine was basically a constant thing unless I wasn't turning or wasn't braking. Last week the whine got really bad, PS reservoir overflowed with foamy fluid. I made it home and figured the PS pump went out, I also had a puddle of fluid under the car. I went to autozone got a new pump and new hoses. When I replaced everything, I saw the steering shaft had rubbed against the return hose line to the PS reservoir causing a hole. So I may not have needed a new pump...nevertheless, I replaced the pump, hoses, and reservoir as I had the top/bottom instead of side/side ports.(may have been the cause of the whine all these years) I now have the side/side ports. Lucas PS fluid in. Anyway, I bled PS system as the forum states. Car off, front wheels off the ground, steer lock to lock. I have turned the wheel lock to lock probably 100 times and I still see tiny bubbles. With the car on, the whine is not as bad, but rather a constant noise that becomes extremely loud when I lock left or lock right or apply any brake pressure. There is a vibration coming from the PS hose to the hydroboost. I feel like the PS pump is starving at points, especially when braking. What else can I do here? There are no kinks in the hoses but there is still some air that doesn't seem to go away. The noise is loud enough when braking that it would be an embarrassment to drive. Anyone have any ideas?
