I just completed the installation of my alkycontrol kit on my tta. Thank you Julio for an outstanding, well made kit! The car has 12,000 miles and is stock with the exception of a K&N filter, magnaflow 3" exhaust, hot wire kit, test pipe and a 93 octane turbotweak chip. I'm using -20 washer fluid with the addition of two bottles of heet until I find a source of methanol. Everything appears to be working as far as the turn on light and the test button. I have the blue knob set at 5. On several occasions the the car felt like it was bogging/losing power under full throttle. One time was on a downshift doing about 50mph. The boost would only hit about 10-12psi, trailed off slightly, come back up, and dropped off again. The next time I rolled into the throttle from a stop. The tires broke loose and when they hooked up it started bogging down again, same as before. It feels similar to KR but my scanmaster showed zero on both occasions. When the alky sprays the o2's jump up to 830-840. It seems to be intermittent, on my other tests the car accelerated smoothly with the boost pegged at 16.5psi.
Could this be a case of too much spray?
