Originally posted by mcss383
Joe, its not defying physics in any way. Porting a ported box into the cab of the car WILL net much louder bass. Removing rear speakers with a sub in the trunk will net more in car bass. Physics works FOR this principle not against...
That's not entirely true. Because of the tuning capabilities, it won't necessarily create more sound, and can cause problems.
If you run the port into the trunk and not into the enclosure, then you're again, making a bandpass. And for it to be effective......you'd have to have a HUGE opening for it to be anything close to a gain. Otherwise, it will actually dampen the output. Because the properties of the bandpass enclosures (4th order), you want the tuning frequency high (like 80 Hz) and cutting two 4" holes will barely get your tuning to 20 Hz IF that.
So remember that when quoting physics laws, you have to observe all the factors. This is why cutting holes just doesn't work. It's best to modify the enclosure itself rather than the vehicle.
If the subs are in a sealed enclosure right now.......that's THE least efficient enclosure subwoofers can be in. You WANT a ported enclosure if want loud, and deep bass. Typically a sealed enclosure will only play down to 55 Hz before rolling off (your power handling rolls off too). Then in ported enclosure, you can play down to the tuned frequency generally without any problems......and has a much lower -3dB point. So if you take the enclosure you have........tune it to 40 Hz with a port......you could get as much as a 3dB increase in efficiency......basically the same increase you would get from doubling your amplifier power. AND you get a better power handling into the lower frequencies. If you're a rock kinda guy......tune from 40-45Hz. If you're a rap/hip hop kinda guy, tune from 30-35 Hz. Keep in mind that the higher you tune, the more SPL you will yield. (It will play higher volumes)
Hope this helps a little. Also helps from hacking your car up only to find that it's not done right.
