I got a little more than a tenth out of my car going from a totally stock set up to a THDP on my TTA. Running mid 11's at the time. It does seem to spool faster though. So not really a good bang for the buck. Port the elbow if you want to see some gain without spending a lot of money.
About $1k for a tenth on a TTA that runs mid 11's.
Subscribed. Charlie, I have been looking for a "true" 2.5 downpipe for a while. No luck.
I will be replacing the junk exhaust on the car with a very good 2.75" design with straight through mufflers
I doubt it was the same system. This one is a Terry Houston.I seen a popular vendor post that dual 2 3/4 system made more power on the dyno than the single 3.5. That was the main reason they were discontinued.
ok. Just clarifying my post... That is why they discontinued the 3.5 single.. because the dual 2.75 made more power on the dyno. Sorry for the d-post.
The test car must have had a lot of power to see an actual difference. Two 2 3/4 pipes is 37.28 sq in cross section. One 3.5" is 30.19 s in cross section. So the dual is about 20% more flow but you would need to feed it with nearly a 4" to prevent restriction at the ex outlet where its critical. Post up those dyn o results. Did they eliminate mufflers as a variable?
