P Paul Bellisario Member Joined Feb 25, 2013 Aug 12, 2014 #1 so i raised the boost to 25 and it pops and breaks up at wot have you guys experienced anything similar ?
T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Aug 12, 2014 #2 Do you have the fuel and octane to support that level of boost? Sent from my QMV7A tablet via Tapatalk.
T turbows6 Member Joined Feb 8, 2006 Aug 12, 2014 #3 Step #1. Turn the boost down a bunch. 25psi is too high of boost to be blindly diagnosing an issue. You've got a lot more leeway under 20psi for problems. Posted from the TurboBuick.Com mobile app
T turbows6 Member Joined Feb 8, 2006 Aug 12, 2014 #4 At 25 pounds you can blow a head gasket or worse within 2 seconds. Posted from the TurboBuick.Com mobile app
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Aug 12, 2014 #5 Tune tool readings are??
B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Aug 12, 2014 #6 If it was ok at lower boost and you have enough octane if look at the ignition.
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Aug 13, 2014 #7 Paul, I thought you cleared it up with the module swap. If your still having problems give me a call. Rick
