Recently got a PLX wide band set up (controller only, no gauge) that I need to wire up to my PowerLogger. Had an LM-1 that was one ugly install. I just used it on a temporary basis here and there, so it was no big deal if I ran wires from under the hood up through the window LOL. But now I need a nice neat permanent install since this will be running full time. Advice and experiences please! Esp. you TurboDave, I seem to recall you run one of these.
1. I need to get switched +12V to the thing. Where's a good spot? Do I need to run a wire over to the fuse box? Is there a good wire to tap into over on the passenger side? What have you done that was clean? I seem to recall the instructions recommending a 5 amp fuse, so I guess it doesn't pull a whole lot of power.
2. Ground - again, anything special here? Where have you found a good ground to be? Just ground it to something metal up there under the dash?
3. This controller box is relatively small - where have you found a good place to mount it out of sight?
4. Pretty big connectors on the wiring going to the actual sensor. How did you get the wires from the passenger compartment to the engine compartment? I'm assuming no one is drilling big holes in their floorboards...
If someone could give me a cookbook on how to neatly install this thing I would really appreciate it! And if this has all been covered in a previous thread (I did do a search but didn't turn up much), please post a link.
thanks
John
thanks
John
