Generally, the more power you make, the colder the plug should be to help prevent detonation. 43's should be ideal for your setup, gapped at a "tight" .035 or .032/.033 with alchy. It's only one heat range colder than stock. And yes, hot temps are these car's worst performance enemy.
Good Luck - Jimmy
