Thats really all you have, the brown signal wire and the output wire--the red 10 gauge charge wire.... do you have battery voltage on the output terminal with the engine off? It should be hot at all times.
That will take out the regulator in the alternator. The L terminal where the brown wire goes requires either a 470 ohm resistor or a 194 light bulb in series with it.
The F terminal can be wired directly to IGN+ voltage with no ill affects. When this is done the L terminal is redundant.
