I'm not clear if the WOT Spark Adv. Window on the Gen-II Translator shows in the PowerLogger or not.
When I look at WOT in PL, I see 19.8 degrees. But, I have the following set in the Gen II (and am running an Exentder Extreme Rev G)
(I run E-85, so don't freak out)
Spark Adv @wot (Trig)
2000: 31.0
2500: 31.0
3000: 28.5
3500: 28.5
4000: 28.5
4500: 27.0
5000: 26.5
5500: 26.5
6000: 26.0
6500: 25.0
Min TPS: 1.5
Max TPS: 5.0
Min Aux: 1.7
Max Aux: 4.5
Min RPM: 2176
Max RPM: 6560
Delay Time: 0.5
MAF Output: GN Ext/Pro
V-Out1 Mode: Spark Control
V-Out2 Mode: AFR Corectn (I output the narrowband from my LM-1 in order to do the A/F Tracking)
(and if I change the other WOT Spark, it has no affect either). What am I missing? PowerLogger Dat file is uploaded
2000: 31.0
2500: 31.0
3000: 28.5
3500: 28.5
4000: 28.5
4500: 27.0
5000: 26.5
5500: 26.5
6000: 26.0
6500: 25.0
Min TPS: 1.5
Max TPS: 5.0
Min Aux: 1.7
Max Aux: 4.5
Min RPM: 2176
Max RPM: 6560
Delay Time: 0.5
