F fleebag Member Joined Jan 13, 2007 Feb 29, 2012 #1 ok i posted on erics forum as well i just finished trans rebuild again and made a cple runs this morning car seems sluggish no KR 25ish psi BLM 147 FP 83LBS Attachments 22912r1.dat 61.5 KB · Views: 43 22912r2.dat 66.5 KB · Views: 36 22912c.dat 66.5 KB · Views: 35
T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Feb 29, 2012 #2 Well, your fuel pressure is WAY too high. Subtracting the 25psi of boost from it and you have that leaves you with 58psi static pressure. And with such high fuel pressure and you still have extrodinarilly high BLM indicates you've got some issues to deal with.
F fleebag Member Joined Jan 13, 2007 Feb 29, 2012 #3 ok, that is a start. thanks, going to set fp again at idle. curious on that.. if i am good at idle what would cause it to raise more? vacuum lines or block leak?
F fleebag Member Joined Jan 13, 2007 Feb 29, 2012 #5 aminga said: Do you have an extender chip? Click to expand... nah, TT Speed Density Alky
