Photos. Is my rjc boost controller hooked up right?
trbogn
Does this look like it is installed correctly? RJC boost controller.
Thanks.
thats not an rjc but you have it hooked up correctly
the way its adjusted its set for max boost
Great, thanks. I bought it from rjc.
I was only getting like 18 pounds of boost as it was set up in this photo. I tightened up my wastegate rod a few turns and loosened the rjc controller, so I can up the boost via the rjc controller. This is how its done right?
Thanks.
Just throwing this out there as advise. Put some zip ties on the ends of the lines. You should also invest in some t- bolt clamps ,18 lbs is a lot of boost.
My rjc looks the same...the directions show a different one in the pic. I believe it said something about a new version...Mike
