Got some questions about a T-Type I recently picked up. I've done some searches, but can't find the info that I'm looking for.
The car is an 87 T, someone put some wrench time & $ into it a long time ago, I'm guessing the build is from sometime in the late 90's.
The questions I have are.
The car has a 71mm Turbo with a 4" intake, the intake tube & everything is 4", then it necks down to 3" for the stock MAF. Will going with a 3.5" LS1 MAF & translator help a good bit with power?
The car also has a 3" DP, that goes back to a stock cat, then someone added what looks like a 2-1/4" exhaust with a stockish looking muffler from the cat back, how bad is this affecting my performance?
As I said someone put some money into this build a while back. Here is a list of what I've found so far.
70mm Accufab TB & Accufab Plenum
Billet Fuel rails w/ Braided Stainless lines, big regulator, SX external fuel pump & big billet fuel filter.
Dual Flex a lite fans
Huge Turbonetics Front mount.
Billet Roller Rockers
Turbonetics Wastegate
Turbonetics Godzilla BOV setup to recirculate ( probably going to remove all of this )
Tranny has a stall, stage right & shift kit, but it's starting to flare.
40# injectors & an unknown chip ( going with 60#ers & probably a TT chip )
It's also got forged pistons & ported heads ( Don't know who did the work )
But back to the original questions, how much better are 3.5" maf's & is the 2-1/4" exhaust choking the hell out of the car?
