phillyvader
- Aug 8, 2009
Hey guys, i have an 87 gn, it came with the breathers in the valve covers and the block off at the turbo when i bought it. I stuck a 4.1 in it, re used all parts, im blowing oil thru breathers pretty good on 20 psi stock turbo. Now the pcv valve that is in there is the same valve i can buy at autozone, question is ...in boost...is boost coming from either direction? It looks like boost would come up from the intake where the gromet is and it would also come thru the vacuum block so how would this stop oil from getting into the intake? Is there a better set up? thanks
