p/inj fuse
tcomo75
just got my motor back in the car and now it keeps blowing the 15 amp fuse marked p/inj the fuel pump will come on but fuse blows every time
I'm having the same exact problem please help my budget is running low almost done the build,every time i get it back I'm running lean,i wouldn't have known that if i didn't have a air/fuel gauge
Connector that was plugged into the oil pressure switch near the oil filter, is shorting on the header. Remove it completely, tape the wires and tuck them into the engine harness.
Passenger side, up front near the oil filter. The harness runs from the top of the engine, down to the oil pressure switch on the OEM setup. Frequent problem when you have upgraded your oil pressure gauge setup, and have removed the OEM oil pressure switch.
